12 years agoQuartus sythesizes double the on-chip memory bits
I'm testing out how to code and simulate the on-chip memory usage, which is working well. However I've noticed in the Flow Summary window after compiling, it's using double the memory bits that my code is set to use. The Altera-Sim correctly shows me the memory usage that I've coded in HDL, not the "phantom" bits. Could it be an optimization or some other synthesizer option causing this? I've created a really basic HDL file which calls an instantiated MegaWizard single port RAM module to simulate this behavior. Everything is 16bit (input data, RAM width, output data, etc), yet Quartus synthesizes 32 bits in the Flow Summary? Any help is greatly appreciated. Verilog HDL code:
module mem_test (clock, data_in, data_out);
parameter ADDR_WIDTH = 16;
input clock;
input data_in;
output wiredata_out;
single_port_ram RAM1 (address, clock, data_in, wren, data_out);
endmodule
MegaWizard Single Port RAM HDL code:
// megafunction wizard: %RAM: 1-PORT%
// GENERATION: STANDARD
// VERSION: WM1.0
// MODULE: altsyncram
// synopsys translate_off
`timescale 1 ps / 1 ps
// synopsys translate_on
module single_port_ram (
address,
clock,
data,
wren,
q);
input address;
input clock;
input data;
input wren;
output q;
`ifndef ALTERA_RESERVED_QIS
`endif
tri1 clock;
`endif
wire sub_wire0;
wire q = sub_wire0;
altsyncram altsyncram_component (
.address_a (address),
.clock0 (clock),
.data_a (data),
.wren_a (wren),
.q_a (sub_wire0),
.aclr0 (1'b0),
.aclr1 (1'b0),
.address_b (1'b1),
.addressstall_a (1'b0),
.addressstall_b (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clock1 (1'b1),
.clocken0 (1'b1),
.clocken1 (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.data_b (1'b1),
.eccstatus (),
.q_b (),
.rden_a (1'b1),
.rden_b (1'b1),
.wren_b (1'b0));
defparam
altsyncram_component.clock_enable_input_a = "BYPASS",
altsyncram_component.clock_enable_output_a = "BYPASS",
altsyncram_component.intended_device_family = "Cyclone IV E",
altsyncram_component.lpm_hint = "ENABLE_RUNTIME_MOD=NO",
altsyncram_component.lpm_type = "altsyncram",
altsyncram_component.numwords_a = 32,
altsyncram_component.operation_mode = "SINGLE_PORT",
altsyncram_component.outdata_aclr_a = "NONE",
altsyncram_component.outdata_reg_a = "UNREGISTERED",
altsyncram_component.power_up_uninitialized = "FALSE",
altsyncram_component.ram_block_type = "M9K",
altsyncram_component.read_during_write_mode_port_a = "DONT_CARE",
altsyncram_component.widthad_a = 5,
altsyncram_component.width_a = 16,
altsyncram_component.width_byteena_a = 1;
endmodule
