12 years agoHI,
Because this .sv is come from part of my design,it will take some time if you still need testbech. But if you check the the synthesis result in mismatch folder using "Technology Map viewr" and check the output pin " fifoOut_dat", you will found those pin was assign to zero. If you check the the synthesis result in match folder using "Technology Map viewr" and check the output pin " fifoOut_dat", you will found those pin was assign to part of design. Ya-Chau --- Quote Start --- If there's a synthesis bug, I would file a Service Request. I would also be very clear in showing snapshots from gate-level simulation and RTL simulation and what is different, as well as testbenches to run the simulations. Right now it's just the .sv files, which nobody would know how to simulate, let alone where to look for mismatches. --- Quote End ---
