OSchu4's avatar
OSchu4
7 years ago
Quartus synthesis of unconstraint array in a record being part of a generic package.
​Hi guys,
I have little example code:
A generic package:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
package test_pkg is
    generic(
        N : positive := 20
    type t_arr is array(natural range <>) of std_logic_vector(N-1 downto 0);
    type t_rec is record
        data : t_arr(0 to 3);
    end record;
end test_pkg;
package body test_pkg is
end test_pkg;
A instance of the generic package:
library ieee;
package test10_pkg is new work.test_pkg
    generic map (
        N => 10
And a rtl-testbench:
library ieee;
use work.test10_pkg.all;
entity tb is
port(
    test1_in  : in  t_rec;
    test1_out1 : out t_rec;
    test1_out2 : out t_arr(0 to 3);
    test1_out3 : out std_logic_vector(9 downto 0);
    test1_out4 : out std_logic;
    test1_out5 : out std_logic_vector(1 downto 0)
end tb;
architecture rtl of tb is
begin
    test1_out1 <= test1_in;
    test1_out2 <= test1_in.data;
    test1_out3 <= test1_in.data(0);
    test1_out4 <= test1_in.data(1)(5);
    test1_out5 <= test1_in.data(1)(3 downto 2);
end rtl;
And a screenshot of the RTL:
Can some explain why the outputs 4 and 5 are not connected in the RTL?
Best Regards
Oliver
  • OSchu4's avatar
    OSchu4
    Please try all of the arrays elements, as you did before!
    force -freeze sim:/tb/test1_in.data(0) 10'hFFF 0
    force -freeze sim:/tb/test1_in.data(1) 10'hFFF 0
    force -freeze sim:/tb/test1_in.data(2) 10'hFFF 0
    force -freeze sim:/tb/test1_in.data(3) 10'hFFF 0
    thank you
  • KennyT_altera's avatar
    KennyT_altera
    Thanks, it is now working. I will log a bug to our developer.
