OSchu4
7 years agoQuartus synthesis of unconstraint array in a record being part of a generic package.
Hi guys, I have little example code: A generic package: library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
package test_pkg is
generic(
N : positive := 20
KennyT_altera
7 years agoI try to run the simulation, it shows that test1-out5 and test1_4 is having zero value. Which is the code that you had written is not recognized in modelsim as well.
If you can prove the code in IEEE std should be usable, I can help to file an enhancement for you. Will attached for you on this.
