Quartus synthesis deletes bits of a variable that gets a constant value
- 5 years ago
The input patterns requested all match to 4 possible cases – the MSB exactly, the LSB exactly, Or values E or 8
This seems to match exactly to the design being inferred by synthesis – what is being compared is ambiguous in the netlist viewer diagram, but it is using the MSB, LSB and these two 4-bit constants to accomplish the comparison.
Since every individual bit takes resources in an FPGA, it makes sense to minimize the functions like this to save resources.
Sorry, no. I am a user of this forum. If you can show simulation waveforms or outputs which you believe demonstrate error(s) we can comment on them. But I am not in a position to analyze your design in detail looking for a possible error.
- NitzanD5 years ago
It can be seen in Signal Tap tool:
You can see here that compare_data0 has only 2 bits, and compare_data1 is not even there.
And also in scheme it can be seen that the constant that goes to comparison is incorrect:In the lab on the FPGA itself it does not compare it correctly. I get 0x800 or 0xC00 for the constants which means only the two MSBs are changing.
I am adding here again the code://---------------------------------------------------------------------------------------------------
module HT3Input12 (
input selector_msb,
input selector_lsb,
input [11:0] InData0,
input [11:0] InData1,
output check
);wire [11:0] Data0 = InData0;
wire [11:0] Data1 = InData1;reg [11:0] Compare_data0;
reg [11:0] Compare_data1;
// Selectors MAP
// 00 - Send 0s on all pins
// 01 - Send a series of '101010...' , first bit is '1'
// 10 - Send a series of '010101...' , first bit is '0'
// 11 - Send 1s on all pins
always @(*)
case ({selector_msb,selector_lsb})
2'b00:
begin
Compare_data0 = 12'd0;
Compare_data1 = 12'd0;
end
2'b01:
begin
Compare_data0 = 12'hABC;
Compare_data1 = 12'h789;
end
2'b10:
begin
Compare_data0 = 12'b101010101010;
Compare_data1 = 12'b101010101010;
end
2'b11:
begin
Compare_data0 = 12'hFFF;
Compare_data1 =12'hFFF;
end
endcase
assign check = ((Data0 == Compare_data0) && (Data1 == Compare_data1)) ? 1'b1 : 1'b0 ;
endmodule
//---------------------------------------------------------------------------------------------------Do you know how can I report a bug on Quartos?
