15 years agoQuartus synthesis constrain
In my project, the following code was to delay the data, I want to use the logic elements to implement in fpga, but the Quartus automatically use altshift_taps to implement which will cost one M9K. Does there any constrains to constrain it using logic elements? Thanks, FPGA: EP3C40 QUARTUS II 8.1 -- -- delay the input data -- pes_ua_array(0) <= pes_ua; pes_ua_fs_array(0) <= pes_fs_ua; pes_ua_delay: for i in 1 to 13 generate process(rst,clk) begin if (rst = '1') then pes_ua_array(i) <= (others=>'0'); pes_ua_fs_array(i) <= '0'; elsif (clk'event and clk = '1') then if (pes_v_ua = '1') then pes_ua_array(i) <= pes_ua_array(i-1); pes_ua_fs_array(i) <= pes_ua_fs_array(i-1); end if; end if; end process; end generate;
