17 years ago
quartus_stp tcl scripts?
I'm looking for information on how to script quartus_stp. I typically instantiate a megawizard plugin generated stp component. I can then do this:
quartus_stp myproject --create_signaltap_hdl_file --stp_file=cli.stp
But I would like to know how to do the following from a quartus_stp tcl script:
set the jtag target
select a signaltap instance if there are more than one
group some signals
set trigger
run until trigger
grab the data into a tcl array or to stdout
I can't seem to find any documentation on how to do this. I would be happy for pointer to docs or sample scripts on this issue.
    I expect that the are no other stp commands than those listed in quartus ii scripting reference manual. Do you know this document?
    Thank you for your reply. Yes I'm familiar with the document. It only describes the command line parameters and not any tcl commands for performing stp operations like I mentioned. I was hoping that it would be possible to do everything you can do from the GUI from tcl :(
    Thanks! It appears that the information that I'm looking for is in the TCL API section. I'll check it out.
    BTW, I found scripting signaltap itself kind of a pain. The sourceProbe and memory content editor (documented in the same doc as the signaltap api i believe) lend themselves to scripting far better than signaltap.
