  • Hi,
    Deleting workaround link & comment as it is not a permanent fix. As of now, we already fixed the internal server issue and please try again to download Quartus 9.1SP1 using the same link below:
    https://www.intel.com/content/www/us/en/programmable/downloads/software/prog-software/91sp1.html
    Make sure you turnoff your internet browser pop-up blocker. We will close this thread since we verified that issue was fixed.
    Joseph
    Intel Customer Support
    • LAnde13's avatar
      LAnde13
      ​Thanks for fixing the link. It works now.
  • Vicky1's avatar
    Vicky1
    I also realized the same behavior. I would like to suggest that, try to use latest used device compatible Quartus version & edition.
    Try by using standalone programmer for Quartus 18.1 Lite edition from 'Additional Software' from link below,
    http://fpgasoftware.intel.com/18.1/?edition=lite
    Please let me know, if you have any different concern.
    Vicky
    • LAnde13's avatar
      LAnde13
      ​Hi,
      I have observed some vague behaviour when I tried to program the legacy .pof file (generated with quartus 9.0 tool) using 13.1 programmer. Checked program and verify boxes on programmer, program says success and verify fails. Examine returns wrong checksum indicating programming also was not done properly.
      Above behaviour is not observed when programmed using Quartus 9.0 programmer. Hence I want to give the supplier the stand alone programmer link which works properly.
      I was under impression that any version Quartus programmer can be used to program .pof file generated by old versions of quartus.
      Another issue I found is typing on Intel community site takes so long as the response is very slow. It took 45 minutes to type this message!
  • Vicky1's avatar
    Vicky1
    '​Hi,
    Above behaviour is not observed when programmed using Quartus 9.0 programmer. Hence I want to give the supplier the stand alone programmer link which works properly.' --------- Alright, I have reported this stand alone programmer link issue to Intel IT team & it may take some time to fix it, once I got any update I will late you know.
    'I was under impression that any version Quartus programmer can be used to program .pof file generated by old versions of quartus.' ------- Recommended to use same Quartus tool & stand alone programmer version.
    'Another issue I found is typing on Intel community site takes so long as the response is very slow. It took 45 minutes to type this message!' --- ----- You can report issue/feedback here,
    https://www.intel.com/content/www/us/en/forms/corporate/webmaster-contact-us.html
    Vicky
