Quartus stand alone programmer download link doesn't work. It gives an error that file not found. Version 9.1
'Hi,
I have observed some vague behaviour when I tried to program the legacy .pof file (generated with quartus 9.0 tool) using 13.1 programmer. Checked program and verify boxes on programmer, program says success and verify fails. Examine returns wrong checksum indicating programming also was not done properly.
Above behaviour is not observed when programmed using Quartus 9.0 programmer. Hence I want to give the supplier the stand alone programmer link which works properly.' --------- Alright, I have reported this stand alone programmer link issue to Intel IT team & it may take some time to fix it, once I got any update I will late you know.
'I was under impression that any version Quartus programmer can be used to program .pof file generated by old versions of quartus.' ------- Recommended to use same Quartus tool & stand alone programmer version.
'Another issue I found is typing on Intel community site takes so long as the response is very slow. It took 45 minutes to type this message!' --- ----- You can report issue/feedback here,
https://www.intel.com/content/www/us/en/forms/corporate/webmaster-contact-us.html
Vicky
