10 years agoquartus_sta won't run after "Succesful" Fitter run
Hi, I'm trying to move to a shell script for this first time with Altera tools and I am getting an error: Error: Can't run TimeQuest Timing Analyzer (quartus_sta) -- Fitter (quartus_fit) faile...
10 years agoHi,
>>> Error: Can't run TimeQuest Timing Analyzer (quartus_sta) -- Fitter (quartus_fit) failed or was not run. In most cases this error is real. For some reason quartus_map or quartus_fit did fail. Take a look at the end of <your qsf name>.map.rpt and <your qsf name>.fit.rpt and make sure it's successfully completed. >>> 1. Why isn't the fitter completion being saved? Here is an example of the simplest possible working script: quartus_map --64bit --read_settings_files=on --write_settings_files=off <qpf_name> -c <qsf_name> quartus_fit --64bit --read_settings_files=off --write_settings_files=off <qpf_name> -c <qsf_name> quartus_asm --64bit --read_settings_files=off --write_settings_files=off <qpf_name> -c <qsf_name> quartus_sta <qpf_name> -c <qsf_name> >>> 2. Like for example: what is "read_settings_files=on" do? >>> 3. (And what documentation is this information in - none that I can find?) You can find this info in "Quartus II Scripting Reference Manual". Just google the name.
