wilfleth
3 years agoquartus simulation not working
Ive been trying to run a simulation on quartus, however I keep getting this error:
I'm not sure what I'm doing that causes this error. My top level compiled without any errors so I don't th...
- 3 years ago
There is a feature in quartus that can convert bdf to hdl. Can you simulate using hdl after converting the bdf? And see if Questa point to any of the lines?
SyafieqS
3 years agoThe error is clearly indicated what is wrong, could you please give snippet of the code?
Any critical warning during compilation?
- wilfleth3 years ago
There was no critical error during compilation. I used a block diagram so I'm not sure how I can look at the code to determine whats causing the error to occur
