9 years ago[Quartus] RTL viewer logic gates
Hello, There is an option to see the basic logic gates and elements in RTL viewer? such as or, nor, and gates used in design? thanks
9 years ago --- Quote Start --- The RTL view is a higher level of abstraction from the gates. To see these, you need the technology map viewer. --- Quote End --- Do you mean the post-map tech map viewer, because the post-fit tech map viewer will not show this. The whole point of the tech map viewer is to show FPGA resources used to implement the design, not logic gates. The RTL viewer used to show logic gates and Karnaugh maps for logic functions, but I don't think it does that anymore. I haven't seen them in there in years.
