Quartus quit unexpectedly
Thanks for this useful information.
'I think the problem is both project related and quartus related, because if I use quartus prime to compile the same project, it works good, that means the code is correct' - - which one is other Quartus edition(Lite/Std) you mean where it works good?
' if I modify the code a little bit, delete the gpio in the code, the quartus prime pro can compile it correctly. It looks like a bug of the quartus prime pro.'---- may I know the which gpio you have deleted, please?
Thank you for your cooperation....
Vicky
Hi Vicky,
I'm using quartus standard edition 18.1 which works good in this case, and gpio is: GPIO Intel FPGA IP, Bidir. I simplified the project and attached the archive in this mail, you will understand this issue easily if you just run it . Thanks.
