DNguy4's avatar
DNguy4
8 years ago
Quartus quit unexpectedly
I am using Quartus 18.0.1 and it quit unexpectedly several times today during synthesis and analysis step with the following error message. Any idea how to deal with this?
Problem Details
Error:
*** Fatal Error: Access Violation at 00007FF95F2F9CA8
Module: quartus_syn.exe
Stack Trace:
0x39ca7: HDB_DESIGN_UNIT::get_library + 0x2b (DB_HDB)
0x36512: QIS_RTL_STAGE::IMPL::process_pre_compiled_partition + 0x302 (synth_qis)
0x32310: QIS_RTL_STAGE::IMPL::elaborate + 0x1a0 (synth_qis)
0x4e1cf: QIS_RTL_RECURSIVE_ELABORATION::after_elaboration + 0x7f (synth_qis)
0x339e0: QIS_RTL_STAGE::IMPL::elaborate + 0x1870 (synth_qis)
0x16a68: qis_elaborate + 0x168 (synth_qis)
0x16442: TclNRRunCallbacks + 0x62 (tcl86)
0x17c4d: TclEvalEx + 0x9ed (tcl86)
0xa6a8b: Tcl_FSEvalFileEx + 0x22b (tcl86)
0xa5136: Tcl_EvalFile + 0x36 (tcl86)
0x13ab0: qexe_evaluate_tcl_script + 0x340 (comp_qexe)
0x12c8f: qexe_do_tcl + 0x33f (comp_qexe)
0x182ce: qexe_run_tcl_option + 0x5ee (comp_qexe)
0x243c3: qcu_run_tcl_option + 0xd43 (comp_qcu)
0x11d9: qsyn2_tcl_process_default_flow_option + 0xa9 (quartus_syn)
0x17bca: qexe_run + 0x3aa (comp_qexe)
0x18c63: qexe_standard_main + 0xb3 (comp_qexe)
0x40c9: qsyn2_main + 0x129 (quartus_syn)
0x13c58: msg_main_thread + 0x18 (CCL_MSG)
0x14f6e: msg_thread_wrapper + 0x6e (CCL_MSG)
0x1e920: mem_thread_wrapper + 0x70 (ccl_mem)
0x13041: msg_exe_main + 0xa1 (CCL_MSG)
0x5764: __scrt_common_main_seh + 0x11c (quartus_syn)
0x8363: BaseThreadInitThunk + 0x13 (KERNEL32)
0x6e820: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus_syn
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 18.0.1
Build: 261
Edition: Pro Edition
  • Tricky's avatar
    Tricky
    If you have deleted the db and incremental_db folders, and it keeps happening, you may need to raise a support ticket.
  • DNguy4's avatar
    DNguy4
    Thanks Tricky. deleting qdb helps but any idea why it helps? Some files in there are corrupted?
  • Tricky's avatar
    Tricky
    No idea. But it's been an answer for a long time
