JOHI
Contributor
7 years agoQuartus programmer bug report: 13 crashes of Quartus in 3 days + solution
Hello, I share this info because it might be of help to the developers to get Quartus more stable: Symptom: Q17.1 Q18.1 crash at the end of the compile cycle. The program is compiled, but just aft...
JOHI
Contributor
7 years ago
Hello KYeoh,
No, cleaning did not make any difference.
But, as explained in detail above, when I no longer needed the time-limited sof, because I obtained the necessary licenses, the crashes did no longer happen.
Since crashes seem to happen in the programmer part (see stack traces), your question regarding the relationship between cleaning and crashing during compile is something I am very interested in to know more about; After restarting Quartus, I could download the .sof that was generated during compile, and is was OK.
Can you explain the background of your question?
To be clear: Buying the software solved my issue but it would be nice is the lite version of Quartus also became more stable.
Johi.
