Quartus problems caused by Windows display language the non English
- 1 year ago
No solutioın yet, we accept the solution(?) to closed the case, we'll move to AnotherMadeDevice
If the error still exists with cmd line, please share us your testcase shows the error for further investigation. Thanks
a) It is very good that you got the problem. But i do not have any idea what is the problem, if you share more info i'll do my best to understand it.
b) If you lead me that how to run tool via command line i can help you. Cmd line can be an option but i think it should not be unique method. For that reason i did not examine the user manuals of cmd usage ever.
c) I have shared the error message as visual and also .txt file. What do you need more to check, please inform me.
c1) You are not volunteer to re produce problem in your side but i strongly suggest to do it, other wise by you guidance performance we'll moved to another fpga solution in year the 2025. Intel can solve this problem with proper patch, i trust you.
Best regards.
- efe18641 year ago
