Quartus Pro bug report: erroneous generation of warning 21569
Thank you, @Nurina .
If the engineering team does decide to make any improvements on this issue, I would love to know about it. Otherwise, I think we can close out this case.
Thanks again,
-Roee
honestly, I'm unable to determine from VHDL standard lecture if the queried error message is a bug or a feature required by the language. The fact that the message doesn't occur in previous QPP versions can't answer the question.
I presume engineering team has an idea why they consider the error check necessary, would be helpful to know the reason.
Frank
- roeekalinsky3 years ago
Contributor
I too would be interested to know their specific reasons.
As I understand their response, I don't think they're even claiming that their check is required by the VHDL language standard. Rather, it seems they're regarding this is a code quality check or linting check of sorts. And hence WARNING and not ERROR, presumably. Though I would say even as a linting check it is still overzealous, given the limitations of the simplistic analysis that they're doing that causes it to issue warnings on perfectly good code.
As it pertains to the VHDL language standard, the VHDL LRM specifies only that "It is an error if execution of a function completes by any means other than the execution of a return statement." In the code example I provided, execution of the function always completes by execution of a return statement. The code example fully satisfies the requirement specified in the LRM.If there's another relevant requirement somewhere in the LRM that I missed, I'd love to see a reference to it. I'm all for strict compliance with the LRM on all sides. And good quality code beyond that.
-Roee
