alexislms
Contributor
3 years agoQuartus pro 22.4 crashing
3 versions later still crashing.
Quartus pro 22.1: https://community.intel.com/t5/Intel-Quartus-Prime-Software/Quartus-Pro-22-1-crashing/m-p/1391215
At synthesis:
Problem Details
Error:
In...
- 3 years ago
Richard,
An IPS ticket has been opened for this.
alexislms
Contributor
3 years agoProblem Details Error: Internal Error: Sub-system: CDB_SGATE, File: /quartus/db/cdb_sgate/cdb_sgate_compatible_registers.cpp, Line: 437 m_oterm_2_set_id_map.find(iname_id) == m_oterm_2_set_id_map.end() Stack Trace: Quartus 0x1c57bf: CDB_SGATE_COMPATIBLE_REGISTERS::copy_map_entry(CDB_SGATE_COMPATIBLE_REGISTERS*, unsigned int) + 0x1ff (db_cdb_sgate) Quartus 0x1261ce: CDB_SGATE_NETLIST::copy_members_to_partitioned_netlist(CDB_SGATE_NETLIST*) + 0x4ae (db_cdb_sgate) Quartus 0x233a6b: sutil_get_partition_netlists(std::vector<CDB_SGATE_NETLIST*, std::allocator<CDB_SGATE_NETLIST*> >*, CDB_SGATE_NETLIST*, CDB_SGATE_HIERARCHY*, CMP_FACADE*, SUTIL_PARTITION_BOUNDARIES&, bool) + 0xa2b (synth_sutil) Quartus 0x24f4c4: SYNTH::QIS::AUTO_PARTITION_MANAGER::partition() + 0x21e (synth_qis) Quartus 0x277a5b: SYNTH::QIS::SYNTHESIS_FLOW::run_parallel_mls_in_helper_processes() + 0x179 (synth_qis) Quartus 0x27f0fe: SYNTH::QIS::SYNTHESIS_FLOW::mls() + 0x32e (synth_qis) Quartus 0x280a0f: SYNTH::QIS::SYNTHESIS_FLOW::run_current_phase() + 0x36f (synth_qis) Quartus 0x28107f: SYNTH::QIS::SYNTHESIS_FLOW::run_full_flow(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool, bool) + 0x44d (synth_qis) Quartus 0x182282: QIS_RTL_STAGE::IMPL::synthesize(QHD_PARTITION&, bool, bool) + 0x64c (synth_qis) Quartus 0x182578: QIS_RTL_STAGE::synthesize(QHD_PARTITION&, bool, bool) + 0x12 (synth_qis) Quartus 0xadc6f: qis_synthesize + 0x241 (synth_qis) Quartus 0x50fb7: TclNRRunCallbacks + 0x47 (tcl8.6) Quartus 0x527df: TclEvalEx + 0x94f (tcl8.6) Quartus 0xfa3a6: Tcl_FSEvalFileEx + 0x266 (tcl8.6) Quartus 0xfa4be: Tcl_EvalFile + 0x2e (tcl8.6) Quartus 0x2a8fc: qexe_evaluate_tcl_script(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 0x3de (comp_qexe) Quartus 0x2dd73: qexe_do_tcl(QEXE_FRAMEWORK*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&, bool, bool) + 0x4c2 (comp_qexe) Quartus 0x2ee7b: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x66e (comp_qexe) Quartus 0x6d1ec: QCU::DETAIL::intialise_qhd_and_run_qexe(QCU_FRAMEWORK&, FIO_PATH const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x9c (comp_qcu) Quartus 0x6d638: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x343 (comp_qcu) Quartus 0x409075: qsyn2_tcl_process_default_flow_option(ACF_VARIABLE_TYPE_ENUM, char const*) + 0x501 (quartus_syn) Quartus 0x3421d: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0xba2 (comp_qexe) Quartus 0x408ace: qsyn2_main(int, char const**) + 0x139 (quartus_syn) Quartus 0x4e546: msg_main_thread(void*) + 0x10 (ccl_msg) Quartus 0x4f764: msg_thread_wrapper(void* (*)(void*), void*) + 0x8c (ccl_msg) Quartus 0x1f568: mem_thread_wrapper(void* (*)(void*), void*) + 0x98 (ccl_mem) Quartus 0x10f3a: err_thread_wrapper(void* (*)(void*), void*) + 0x1e (ccl_err) Quartus 0xb7f5: thr_thread_wrapper + 0x15 (ccl_thr) Quartus 0x4f684: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xd8 (ccl_msg) Quartus 0x40898e: main + 0x26 (quartus_syn) System 0x22555: __libc_start_main + 0xf5 (c) Quartus 0x4088b9: _start + 0x29 (quartus_syn) End-trace Executable: quartus Comment: None System Information Platform: linux64 OS name: CentOS Linux OS version: 7 Quartus Prime Information Address bits: 64 Version: 22.4.0 Build: 94 Edition: Pro Edition
