alexislms
Contributor
4 years agoQuartus Pro 22.1 crashing
Quartus keeps crashing when I open the RTL viewer: Problem Details Error: Internal Error: Sub-system: NPP, File: /quartus/nlv/npp/npp_bus_grouping.cpp, Line: 1020 child_oterm->is_single() ...
alexislms
Contributor
3 years agoProblem Details
Error:
*** Fatal Error: Segment Violation: faulting address=0x12639e00, PC=0x12639e00 : 0x12639e00:
Module: quartus
Stack Trace:
Err Handler 0x122f8: ERR_UNWINDER_BACKTRACE::get_stack_trace(void const**, int, int, void*) + 0xe0 (ccl_err)
Err Handler 0x8a1f6: msg_ie_get_call_stack(void*) + 0xc4 (ccl_msg)
Err Handler 0x8ba52: MSG_INTERNAL_ERROR::report_fatal(char const*, void*, bool) + 0x40 (ccl_msg)
Err Handler 0x14fd2: err_report_fatal_exception(char const*, void*, bool) + 0x6f (ccl_err)
Err Handler 0x15b1c: err_sigaction_handler + 0x191 (ccl_err)
System 0x12cf0: (pthread)
Other 0x12639e00:
End-trace
Executable: quartus
Comment:
None
System Information
Platform: linux64
OS name: CentOS Stream
OS version: 8
Quartus Prime Information
Address bits: 64
Version: 22.2.0
Build: 94
Edition: Pro Edition
- alexislms3 years ago
Contributor
Problem Details
Error:
Internal Error: Sub-system: NVD, File: /quartus/nlv/nvd/nvd_netlist_component.cpp, Line: 2879m_child_vec[port_index - min_index] == NULLStack Trace:Quartus 0x670f2: NVD_PORT_BUS::retrieve_child_hid(int) const (nlv_nvd)Quartus 0x4b2f81: NPP_BUS_GROUPING::group_child_port(NVD_INSTANCE*, HDB_INSTANCE_NAME*, NVD_PORT_SINGLE*, std::map<HDB_INSTANCE_NAME*, NVD_PORT_BUS*, std::less<HDB_INSTANCE_NAME*>, std::allocator<std::pair<HDB_INSTANCE_NAME* const, NVD_PORT_BUS*> > >*) + 0x83b (quartus_npp)Quartus 0x4b3613: NPP_BUS_GROUPING::group_child_ports_of_instance(NVD_INSTANCE*) + 0x2e1 (quartus_npp)Quartus 0x4b4109: NPP_BUS_GROUPING::start(int, NVD_INSTANCE*) + 0xc3 (quartus_npp)Quartus 0x432f8e: NPP_SGATE_OP::executing(CMP_FACADE*, bool&) + 0x1420 (quartus_npp)Quartus 0x41f679: NPP_FRAMEWORK::execute() + 0x3f (quartus_npp)Quartus 0x3461a: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0xf52 (comp_qexe)Quartus 0x41d309: npp_main(int, char const**) + 0x6d (quartus_npp)Quartus 0x4de26: msg_main_thread(void*) + 0x10 (ccl_msg)Quartus 0x4f44e: msg_thread_wrapper(void* (*)(void*), void*) + 0x8c (ccl_msg)Quartus 0x1f198: mem_thread_wrapper(void* (*)(void*), void*) + 0x98 (ccl_mem)Quartus 0xfb0a: err_thread_wrapper(void* (*)(void*), void*) + 0x1e (ccl_err)Quartus 0xb7d5: thr_thread_wrapper + 0x15 (ccl_thr)Quartus 0x4f36e: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xd8 (ccl_msg)Quartus 0x41d153: main + 0x26 (quartus_npp)System 0x3ad85: __libc_start_main + 0xe5 (c)Quartus 0x418909: _start + 0x29 (quartus_npp)End-trace
Executable: quartus
Comment:
None
System Information
Platform: linux64
OS version: 8
Address bits: 64
Version: 22.2.0
Build: 94
