alexislms
Contributor
4 years agoQuartus Pro 22.1 crashing
Quartus keeps crashing when I open the RTL viewer: Problem Details Error: Internal Error: Sub-system: NPP, File: /quartus/nlv/npp/npp_bus_grouping.cpp, Line: 1020 child_oterm->is_single() ...
alexislms
Contributor
4 years agoAfter few compilation runs and/or a few SignalTap acquisitions, it takes over 40GB idle. Closing the project/SignalTap doesn't free that memory. I have to close Quartus to free all that memory.
Quartus Pro 22.2 has a very bad memory management, it leaks a huge amount of memory...
SignalTap DataLog is disabled:
and closing it doesn't free the memory anyway.
- alexislms4 years ago
Contributor
Problem Details Error: Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/quartus_interface/qi_common/vpr_qi_fitter_delay_info_api.cpp, Line: 1256 Internal Error Stack Trace: Quartus 0xcb31c: vpr_qi_jump_to_exit(e_vpr_exit_arg, char const*, int) + 0x6b (fitter_vpr20kmain) Quartus 0x2ff68d: vpr_exit_at_line + 0x79 (fitter_vpr20kmain) Quartus 0x2ff614: vpr_exit_at_line (fitter_vpr20kmain) Quartus 0x116ad4: void tbb::detail::d1::dynamic_grainsize_mode<tbb::detail::d1::adaptive_mode<tbb::detail::d1::auto_partition_type> >::work_balance<tbb::detail::d1::start_for<UDM_ROUTING::NODE_ITER_BY_TYPE_RANGE, l_assign_node_classes_new(QTL_HASH_LITE<int, int, QTL_OPS<int, void> >&)::{lambda(UDM_ROUTING::NODE_ITER_BY_TYPE_RANGE const&)#1}, tbb::detail::d1::auto_partitioner const>, UDM_ROUTING::NODE_ITER_BY_TYPE_RANGE>(tbb::detail::d1::start_for<UDM_ROUTING::NODE_ITER_BY_TYPE_RANGE, l_assign_node_classes_new(QTL_HASH_LITE<int, int, QTL_OPS<int, void> >&)::{lambda(UDM_ROUTING::NODE_ITER_BY_TYPE_RANGE const&)#1}, tbb::detail::d1::auto_partitioner const>&, UDM_ROUTING::NODE_ITER_BY_TYPE_RANGE&, tbb::detail::d1::execution_data&) [clone .cold] + 0x552 (fitter_vpr20kmain) Quartus 0x66d929: tbb::detail::d1::start_for<UDM_ROUTING::NODE_ITER_BY_TYPE_RANGE, l_assign_node_classes_new(QTL_HASH_LITE<int, int, QTL_OPS<int, void> >&)::{lambda(UDM_ROUTING::NODE_ITER_BY_TYPE_RANGE const&)#1}, tbb::detail::d1::auto_partitioner const>::execute(tbb::detail::d1::execution_data&) + 0x79 (fitter_vpr20kmain) Quartus 0x161d3: tbb::detail::r1::task_dispatcher::execute_and_wait(tbb::detail::d1::task*, tbb::detail::d1::wait_context&, tbb::detail::d1::task_group_context&) + 0x763 (tbb) Quartus 0x92052: vpr_qi_annotate_fdi_delays_to_rr_graph(bool) [clone .cold] + 0x4e9 (fitter_vpr20kmain) Quartus 0x6a6853: aa_rdc_load_and_store_fdi_data() + 0x33 (fitter_vpr20kmain) Quartus 0x69ca82: altera_arch_initialize_architecture_data() + 0x1a42 (fitter_vpr20kmain) Quartus 0x69aae0: init_arch_pre_packing() + 0x40 (fitter_vpr20kmain) Quartus 0x68e58a: vpr_initialize(int, char**) + 0x8a (fitter_vpr20kmain) Quartus 0x5a121e: VPR_QI_FACADE::load(VPR_QI_FACADE::e_vpr_load_state) + 0x36e (fitter_vpr20kmain) Quartus 0x5a0e9e: VPR_QI_FACADE::initialize_state_for_placer() + 0xe (fitter_vpr20kmain) Quartus 0x10caf5: VPR_QI_FACADE::vpr_bsyn_flow() + 0x25b (fitter_vpr20kmain) Quartus 0x1029a9: FDRGN_EXPERT::run_place() + 0x179 (fitter_fdrgn) Quartus 0x102f70: FDRGN_EXPERT::place() + 0x490 (fitter_fdrgn) Quartus 0x3c2f7: fit2_fit_place_auto + 0x163 (comp_fit2) Quartus 0x4c942: TclNRRunCallbacks + 0x42 (tcl8.6) Quartus 0x287a7: fit2_fit_place + 0x2fb (comp_fit2) Quartus 0x4c942: TclNRRunCallbacks + 0x42 (tcl8.6) Quartus 0x4de7b: TclEvalEx + 0x68b (tcl8.6) Quartus 0xf3f0e: Tcl_FSEvalFileEx + 0x25e (tcl8.6) Quartus 0xf3ffe: Tcl_EvalFile + 0x2e (tcl8.6) Quartus 0x2a8fc: qexe_evaluate_tcl_script(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 0x3de (comp_qexe) Quartus 0x2dd73: qexe_do_tcl(QEXE_FRAMEWORK*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&, bool, bool) + 0x4c2 (comp_qexe) Quartus 0x2eec8: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x66e (comp_qexe) Quartus 0x52f1f: QCU::DETAIL::intialise_qhd_and_run_qexe(QCU_FRAMEWORK&, FIO_PATH const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x99 (comp_qcu) Quartus 0x532f9: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x343 (comp_qcu) Quartus 0x3426a: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0xba2 (comp_qexe) Quartus 0x40ad1c: qfit2_main(int, char const**) + 0x8c (quartus_fit) Quartus 0x4de26: msg_main_thread(void*) + 0x10 (ccl_msg) Quartus 0x4f44e: msg_thread_wrapper(void* (*)(void*), void*) + 0x8c (ccl_msg) Quartus 0x1f198: mem_thread_wrapper(void* (*)(void*), void*) + 0x98 (ccl_mem) Quartus 0xfb0a: err_thread_wrapper(void* (*)(void*), void*) + 0x1e (ccl_err) Quartus 0xb7d5: thr_thread_wrapper + 0x15 (ccl_thr) Quartus 0x4f36e: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xd8 (ccl_msg) System 0x3aca3: __libc_start_main + 0xf3 (c) Quartus 0x406259: _start + 0x29 (quartus_fit) End-trace Executable: quartus Comment: None System Information Platform: linux64 OS name: CentOS Stream OS version: 8 Quartus Prime Information Address bits: 64 Version: 22.2.0 Build: 94 Edition: Pro Edition
