Quartus Pro 22.1 crashing
Adding a divider, SignalTap always crashes (I has never been able to add a divider):
Problem Details
Error:
*** Fatal Error: Segment Violation: faulting address=0x7e48, PC=0x7f7d4c8b3bc0 : 0x7f7d4c8b3bc0: sld_sdr!SDR_TX_VECTERIZED_VIEW_NODE_ATTRIB_DECORATOR::set_value(char const*, char const*) + 0x46
Module: quartus
Stack Trace:
Err Handler 0x122b2: ERR_UNWINDER_BACKTRACE::get_stack_trace(void const**, int, int, void*) + 0xe0 (ccl_err)
Err Handler 0x87f1a: msg_ie_get_call_stack(void*) + 0xc4 (ccl_msg)
Err Handler 0x89776: MSG_INTERNAL_ERROR::report_fatal(char const*, void*, bool) + 0x40 (ccl_msg)
Err Handler 0x14f8c: err_report_fatal_exception(char const*, void*, bool) + 0x6f (ccl_err)
Err Handler 0x15ad6: err_sigaction_handler + 0x191 (ccl_err)
System 0x12ce0: (pthread)
Quartus 0x108bc0: SDR_TX_VECTERIZED_VIEW_NODE_ATTRIB_DECORATOR::set_value(char const*, char const*) + 0x46 (sld_sdr)
Quartus 0x11cd04: SDR_TX_SIGNAL_NODES_GEN2::set_node_tap_mode(int, SDR_DATA_WIRE_TAP_MODE) + 0x58 (sld_sdr)
Quartus 0x122dbb: non-virtual thunk to SDR_TX_SIGNAL_SET_GEN2::set_node_tap_mode(int, SDR_DATA_WIRE_TAP_MODE) + 0x9 (sld_sdr)
Quartus 0xe5286: SEDQ_NODE::is_transition_enabled(bool*) const + 0x4c (sld_sedq)
Quartus 0xe683e: SEDQ_NODE::enable_transition(bool) + 0xdc (sld_sedq)
Quartus 0xe9da8: SEDQ_TX_MANAGER::add_divider(int) + 0x4d6 (sld_sedq)
Quartus 0xfcd91: SEDQ_VIEW::on_add_divider_action() + 0x27 (sld_sedq)
Quartus 0x1741d7: SEDQ_VIEW::qt_static_metacall(QObject*, QMetaObject::Call, int, void**) + 0x63b (sld_sedq)
Quartus 0x2faf93: void doActivate<false>(QObject*, int, void**) + 0x263 (Qt5Core)
Quartus 0x155b82: QAction::triggered(bool) + 0x42 (Qt5Widgets)
Quartus 0x1581de: QAction::activate(QAction::ActionEvent) + 0x9e (Qt5Widgets)
Quartus 0x2d22da: QMenuPrivate::activateCausedStack(QVector<QPointer<QWidget> > const&, QAction*, QAction::ActionEvent, bool) + 0x1da (Qt5Widgets)
Quartus 0x2d9846: QMenuPrivate::activateAction(QAction*, QAction::ActionEvent, bool) + 0xf6 (Qt5Widgets)
Quartus 0x2daa30: QMenu::mouseReleaseEvent(QMouseEvent*) + 0x1d0 (Qt5Widgets)
Quartus 0x19adb8: QWidget::event(QEvent*) + 0x1f8 (Qt5Widgets)
Quartus 0x2dcfe3: QMenu::event(QEvent*) + 0xa3 (Qt5Widgets)
Quartus 0x15befc: QApplicationPrivate::notify_helper(QObject*, QEvent*) + 0x9c (Qt5Widgets)
Quartus 0x163a30: QApplication::notify(QObject*, QEvent*) + 0xcf0 (Qt5Widgets)
Quartus 0x2bffa0: QCoreApplication::notifyInternal2(QObject*, QEvent*) + 0x110 (Qt5Core)
Quartus 0x2da6bf: QMenuPrivate::mouseEventTaken(QMouseEvent*) + 0x79f (Qt5Widgets)
Quartus 0x2da8b6: QMenu::mouseReleaseEvent(QMouseEvent*) + 0x56 (Qt5Widgets)
Quartus 0x1624e2: QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) + 0x212 (Qt5Widgets)
Quartus 0x1b4b7b: QWidgetWindow::handleMouseEvent(QMouseEvent*) + 0x3eb (Qt5Widgets)
Quartus 0x1b7d73: QWidgetWindow::event(QEvent*) + 0x2d3 (Qt5Widgets)
Quartus 0x162f60: QApplication::notify(QObject*, QEvent*) + 0x220 (Qt5Widgets)
Quartus 0x147db8: QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) + 0x6e8 (Qt5Gui)
Quartus 0x149295: QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) + 0x135 (Qt5Gui)
Quartus 0x1236cb: QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 0xbb (Qt5Gui)
Quartus 0x65193: QXcbUnixEventDispatcher::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 0x23 (Qt5XcbQpa)
Quartus 0x2be80a: QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 0x11a (Qt5Core)
Quartus 0x2d7434: QMenuPrivate::exec(QPoint const&, QAction*, std::function<QPoint (QSize const&)>) + 0xd4 (Qt5Widgets)
Quartus 0x2d755b: QMenu::exec(QPoint const&, QAction*) + 0x2b (Qt5Widgets)
Quartus 0x109ffc: SEDQ_VIEW::contextMenuEvent(QContextMenuEvent*) + 0x2e8 (sld_sedq)
Quartus 0x19bb01: QWidget::event(QEvent*) + 0xf41 (Qt5Widgets)
Quartus 0x153439: SEDQ_VIEW::event(QEvent*) + 0x35 (sld_sedq)
Quartus 0x164649: QApplication::notify(QObject*, QEvent*) + 0x1909 (Qt5Widgets)
Quartus 0x1b4fe5: QWidgetWindow::handleMouseEvent(QMouseEvent*) + 0x855 (Qt5Widgets)
Quartus 0x2c7fc7: QCoreApplication::exec() + 0x97 (Qt5Core)
Quartus 0x403f80: qgq_main(int, char const**) + 0x6e (quartus)
Quartus 0x4d1d4: msg_main_thread(void*) + 0x10 (ccl_msg)
Quartus 0x4e67c: msg_thread_wrapper(void* (*)(void*), void*) + 0x8c (ccl_msg)
Quartus 0x23898: mem_thread_wrapper(void* (*)(void*), void*) + 0x98 (ccl_mem)
Quartus 0xfa86: err_thread_wrapper(void* (*)(void*), void*) + 0x1e (ccl_err)
Quartus 0xb8a5: thr_thread_wrapper + 0x15 (ccl_thr)
Quartus 0x4e59c: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xd8 (ccl_msg)
Quartus 0x404068: main + 0x26 (quartus)
System 0x3aca3: __libc_start_main + 0xf3 (c)
Quartus 0x403e69: _start + 0x29 (quartus)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: linux64
OS name: CentOS Stream
OS version: 8
Quartus Prime Information
Address bits: 64
Version: 22.1.0
Build: 174
Edition: Pro Edition
- alexislms4 years ago
Contributor
When I opened SignalTap:
Problem Details Error: Internal Error: Sub-system: HDB, File: /quartus/db/hdb/hdb_pdb.cpp, Line: 89 hdb_asgn_to_position == 0 Stack Trace: Quartus 0x137fb7: HDB_ASGN_CONTAINER::customized_pdb_read(PDB_SEGMENT_TEMPLATE<PDB_HDB_SEG_BASE>&) [clone .cold] + 0x1f (db_hdb) Quartus 0x1a108d: HDB_ASGN_CONTAINER::operator<<(PDB_SEGMENT_TEMPLATE<PDB_HDB_SEG_BASE>&) + 0x16d (db_hdb) Quartus 0x1d835b: HDB_SECTION::operator<<(PDB_SEGMENT_TEMPLATE<PDB_HDB_SEG_BASE>&) + 0x13b (db_hdb) Quartus 0x1a61af: HDB_NAMESPACE::operator<<(PDB_SEGMENT_TEMPLATE<PDB_HDB_SEG_BASE>&) + 0x3f (db_hdb) Quartus 0x22caa: PDB_SEGMENT_READER::finish_reading_all() + 0x6a (db_pdb) Quartus 0x2a3c7: pdb_read_ptr(PDB_ARCHIVE&, char const*, char const*, void (*)(PDB_BASE_SEGMENT&, void*&), void*&, MEM_UTILS_CHUNK_ALLOC*, char const*, int, char const*) + 0x67 (db_pdb) Quartus 0x1c9d06: bool pdb_read<PDB_ARCHIVE, HDB_NAMESPACE>(HDB_NAMESPACE*&, PDB_ARCHIVE&, char const*) + 0x56 (db_hdb) Quartus 0x1c989c: HDB_MODEL_HANDLER::read_file(QDB_FILE const&) const + 0xdc (db_hdb) Quartus 0x1c9795: HDB_MODEL_HANDLER::read_model_from_file(QDB_PATH const&, QDB_FILE const&) const + 0x15 (db_hdb) Quartus 0x39536: QDB_SERVICE_IMPL::get_model_using_handler(QDB_MODEL_HEADER const&, QDB_MODEL_HANDLER*) + 0x156 (db_qdb) Quartus 0x3e4d0: QDB_SERVICE_IMPL::get_model(QDB_PATH const&, bool, bool*) + 0x170 (db_qdb) Quartus 0x81f84: QDB_BASIC_STATE::load_model_on_demand(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) const + 0xc4 (db_qdb) Quartus 0x823b3: QDB_BASIC_STATE::load_raw_model(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool) const + 0xf3 (db_qdb) Quartus 0x81a72: QDB_BASIC_STATE::load(QDB_SERVICE*, QDB_PATH const&, bool, bool*) + 0x952 (db_qdb) Quartus 0x1b0251: QHD_PARTITION_IMPL::load_state(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, QDB_SERVICE*, bool*) + 0x383 (comp_qhd) Quartus 0x11555b: QHD_DATABASE_UTILS::IMPL::load_partition_tree(QHD_PARTITION&, QHD_ENUM_IMPL<QHD_SNAPSHOT_BASE>, QHD_DATABASE_UTILS::LOAD_TYPE, QHD_DATABASE_UTILS::LOAD_SIDE_EFFECTS, bool) + 0x405 (comp_qhd) Quartus 0xd6741: QHD_DATABASE_UTILS::load_design(QHD_ENUM_IMPL<QHD_SNAPSHOT_BASE>, QHD_DATABASE_UTILS::LOAD_TYPE, QHD_DATABASE_UTILS::LOAD_SETTING const&) + 0xd15 (comp_qhd) Quartus 0x966e: QHD_DBMUI_MANAGER_IMPL::load_db(QHD_ENUM_IMPL<QHD_SNAPSHOT_BASE>, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool, bool) + 0xac (comp_qhd_dbmui) Quartus 0x9b9a: QHD_DBMUI_MANAGER_IMPL::load_design(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, QHD_ENUM_IMPL<QHD_SNAPSHOT_BASE>, bool, bool) + 0x1a4 (comp_qhd_dbmui) Quartus 0xd6db: DBMUI_MANAGER::get_qhd_hdb_cmp_action_pt_instance(char const*, QHD_ENUM_IMPL<QHD_SNAPSHOT_BASE>, bool) + 0xcb (db_dbmui) Quartus 0xcc646: qui_get_qhd_hdb_cmp_action_pt_instance(char const*, QHD_ENUM_IMPL<QHD_SNAPSHOT_BASE>, bool) + 0x46 (sys_qui) Quartus 0xca34a: SEDQ_TX_MANAGER::check_node_validity(bool, int) + 0xca (sld_sedq) Quartus 0x13fbb6: SEDQ_TX_MANAGER::open_document(char const*, bool*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 0x5ae (sld_sedq) Quartus 0x13feaa: SEDQ_FRAME_WND::open_file(QString const&) + 0x108 (sld_sedq) Quartus 0xa2c59: QUI_FRAME_MGR::open_file(QString const&, bool, bool, bool) + 0x193 (sys_qui) Quartus 0x137de7: QUI_TOOLS_MENU::sedq_action() + 0x24f (sys_qui) Quartus 0x1338f4: QUI_TOOLS_MENU::qt_static_metacall(QObject*, QMetaObject::Call, int, void**) + 0x20e (sys_qui) Quartus 0x2faf93: void doActivate<false>(QObject*, int, void**) + 0x263 (Qt5Core) Quartus 0x155b82: QAction::triggered(bool) + 0x42 (Qt5Widgets) Quartus 0x1581de: QAction::activate(QAction::ActionEvent) + 0x9e (Qt5Widgets) Quartus 0x107af1: AFCQ_FLOW_NAVIGATOR::item_clicked(QModelIndex const&) + 0x26b (gcl_afcq) Quartus 0x1c2da9: AFCQ_FLOW_NAVIGATOR::qt_static_metacall(QObject*, QMetaObject::Call, int, void**) + 0x2b (gcl_afcq) Quartus 0x2faf93: void doActivate<false>(QObject*, int, void**) + 0x263 (Qt5Core) Quartus 0x3b1c75: QAbstractItemView::clicked(QModelIndex const&) + 0x35 (Qt5Widgets) Quartus 0x3b4fd3: QAbstractItemView::mouseReleaseEvent(QMouseEvent*) + 0x313 (Qt5Widgets) Quartus 0x42b133: QTreeView::mouseReleaseEvent(QMouseEvent*) + 0x163 (Qt5Widgets) Quartus 0x1d80f3: AFCQ_TREE_VIEW::mouseReleaseEvent(QMouseEvent*) + 0x583 (gcl_afcq) Quartus 0x19adb8: QWidget::event(QEvent*) + 0x1f8 (Qt5Widgets) Quartus 0x24566e: QFrame::event(QEvent*) + 0x1e (Qt5Widgets) Quartus 0x3be9a3: QAbstractItemView::viewportEvent(QEvent*) + 0x1b3 (Qt5Widgets) Quartus 0x42ab2c: QTreeView::viewportEvent(QEvent*) + 0x3c (Qt5Widgets) Quartus 0x1d8409: AFCQ_TREE_VIEW::viewportEvent(QEvent*) + 0x2e7 (gcl_afcq) Quartus 0x2bfd20: QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*) + 0xa0 (Qt5Core) Quartus 0x15bed2: QApplicationPrivate::notify_helper(QObject*, QEvent*) + 0x72 (Qt5Widgets) Quartus 0x163a30: QApplication::notify(QObject*, QEvent*) + 0xcf0 (Qt5Widgets) Quartus 0x2bffa0: QCoreApplication::notifyInternal2(QObject*, QEvent*) + 0x110 (Qt5Core) Quartus 0x1624e2: QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) + 0x212 (Qt5Widgets) Quartus 0x1b4e93: QWidgetWindow::handleMouseEvent(QMouseEvent*) + 0x703 (Qt5Widgets) Quartus 0x1b7d73: QWidgetWindow::event(QEvent*) + 0x2d3 (Qt5Widgets) Quartus 0x15befc: QApplicationPrivate::notify_helper(QObject*, QEvent*) + 0x9c (Qt5Widgets) Quartus 0x162f60: QApplication::notify(QObject*, QEvent*) + 0x220 (Qt5Widgets) Quartus 0x2bffa0: QCoreApplication::notifyInternal2(QObject*, QEvent*) + 0x110 (Qt5Core) Quartus 0x147db8: QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) + 0x6e8 (Qt5Gui) Quartus 0x149295: QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) + 0x135 (Qt5Gui) Quartus 0x1236cb: QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 0xbb (Qt5Gui) Quartus 0x65193: QXcbUnixEventDispatcher::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 0x23 (Qt5XcbQpa) Quartus 0x2be80a: QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 0x11a (Qt5Core) Quartus 0x2c7fc7: QCoreApplication::exec() + 0x97 (Qt5Core) Quartus 0x403f80: qgq_main(int, char const**) + 0x6e (quartus) Quartus 0x4d1d4: msg_main_thread(void*) + 0x10 (ccl_msg) Quartus 0x4e67c: msg_thread_wrapper(void* (*)(void*), void*) + 0x8c (ccl_msg) Quartus 0x23898: mem_thread_wrapper(void* (*)(void*), void*) + 0x98 (ccl_mem) Quartus 0xfa86: err_thread_wrapper(void* (*)(void*), void*) + 0x1e (ccl_err) Quartus 0xb8a5: thr_thread_wrapper + 0x15 (ccl_thr) Quartus 0x4e59c: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xd8 (ccl_msg) Quartus 0x404068: main + 0x26 (quartus) System 0x3aca3: __libc_start_main + 0xf3 (c) Quartus 0x403e69: _start + 0x29 (quartus) End-trace Executable: quartus Comment: None System Information Platform: linux64 OS name: CentOS Stream OS version: 8 Quartus Prime Information Address bits: 64 Version: 22.1.0 Build: 174 Edition: Pro Edition
