Quartus Pro (21.4 + 22.1 + 22.2) not loading, no splash screen
Just to be sure, could you check whether the hardware and software requirement are met?
It is weird that you mention that the Quartus work previously and do not work later on.
Few things that you can try out:
1) If you are running antivirus software, try to temporarily disable the antivirus software
2) Run or Install Quartus with Administrator privileges
3) Uninstall the Quartus and make sure there is no leftover file in the folder, then reinstall the Quartus
4) Check with your IT team to see if there is potential software that might be block it from opening
fyi, the current Quartus Pro released version is 22.4. I recommend to get it if you plan to reinstall.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
