8 years agoQuartus Prime Standard Edition - Evaluation license
Hi, I am new to Altera, and came across Quartus prime tool evaluation feature. And it is mentioned in 'Intel FPGA Software installation and licensing' document that it allows to use the tool for 3...
8 years agoHi,
You can create project with all the resources/IP's but after full compilation quartus with 30 days license will not generate .sof which is used for programming (which is used to generate pof/jic files applicable for Quartus STD and Quartus Pro). To work on board you can use Quartus Lite Edition with programming file support which will generate sof files to program board. https://www.altera.com/downloads/download-center.html Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
