JWrig25
6 years agoQuartus Prime Standard 18.1 fails to program my Stratix V GX FPGA board
I am trying to program a Stratix V GX FPGA using Quartus Prime, but whenever I get to the Programmer window and select auto detect I get an error "Unable to scan device chain. On-board programming ha...
User1573261788318367
6 years agoCan you actually see your Stratix V device on the JTAG chain? If not, you have misconfigured your project. Another possibility is that indeed the on-board JTAG is disabled. This can happen when the board configurations pins are configured to use some pre-built image loaded via flash memory or even board DDR RAM. Double-check the board manual to check if there are DIP switches that control the configuration mode.
