malayali
4 years agoQuartus Prime Software system debugging tool support
Hi ,
I'm using the System debugging toolkit from the Quartus prime software and changing Rx and Tx parameters for the DP 1.4 to test loop back, using Arria10 based on our own designed board. Pl cl...
Kshitij_Intel
4 years agoHi,
As I know, there is no button in the TTK GUI to switch between High Gain, and High Data Rate mode. I believe you are changing modes with various AVMM writes, possibly using scripts in the TTK System Console window.
I think High Data rate and high gain modes are defined at compile time. You might have two separate designs, (one high data rate, and one high gain), and tests those separately, is the behavior different?
For Stratix 10 you can try using fully adaptive mode to tune the RX gain.
Thank you
Kshitij Goel
