malayali
4 years agoQuartus Prime Software system debugging tool support
Hi ,
I'm using the System debugging toolkit from the Quartus prime software and changing Rx and Tx parameters for the DP 1.4 to test loop back, using Arria10 based on our own designed board. Pl cl...
Kshitij_Intel
4 years agoHi,
You do not need to close and reopen the toolkit if changing gain mode.
For DP Rates, you should probably use high gain mode as this offers more flexibility over the range of resolutions (rates) that DP runs at. The user guide does document that “in High Data rate mode, AC gain values and DC gain values cannot be controlled individually as done in high gain mode. The recommended AC gain values in high data rate mode include the appropriate setting of DC gain to get the required peaking at respective peaking frequencies."
if using the Intel DP IP, then you probably do not need to use the TK. the protocol does the tuning for you.
Thank you
Kshitij Goel
