9 years agoquartus prime software quit unexpectedly
I have problem with synthesis. I can't find any information about this error code.
Here is the report: problem details Error: *** Fatal Error: Access Violation at 0X00007FFAFF18ED5E Module: quartus_map.exe Stack Trace: 0x1ed5d: HDBX_READER::generate_dependencies + 0x39d (db_hdbx) 0x1e3f0: HDBX_READER::generate_assignments + 0xbb0 (db_hdbx) 0x1f507: HDBX_READER::generate_hdb + 0x107 (db_hdbx) 0x22775: HDBX_READER::read_common + 0x155 (db_hdbx) 0x5068: hdbx_drl_hdbx_read + 0x88 (db_hdbx) 0x22dc4: QSYN_FRAMEWORK::write_qic_databases + 0x514 (quartus_map) 0x21f24: QSYN_FRAMEWORK::write_databases + 0x114 (quartus_map) 0x11378: qexe_do_normal + 0x2a8 (comp_qexe) 0x16142: qexe_run + 0x432 (comp_qexe) 0x16e51: qexe_standard_main + 0xc1 (comp_qexe) 0x1b06b: qsyn_main + 0x51b (quartus_map) 0x13328: msg_main_thread + 0x18 (CCL_MSG) 0x14b0e: msg_thread_wrapper + 0x6e (CCL_MSG) 0x15b00: mem_thread_wrapper + 0x70 (ccl_mem) 0x12a11: msg_exe_main + 0xa1 (CCL_MSG) 0x29862: __tmainCRTStartup + 0x10e (quartus_map) 0x8363: BaseThreadInitThunk + 0x13 (KERNEL32) 0x670d0: RtlUserThreadStart + 0x20 (ntdll) End-trace Executable: quartus_map Comment: None system information Platform: windows64 OS name: Windows 10 OS version: 10.0 quartus prime information Address bits: 64 Version: 16.1.0 Build: 196 Edition: Standard Edition ----------------------------------------------------------------- I have found the code which causes this issue. But I don't know why the code causes the problem. Also, I don't know how to solve it. Here is the code: initial begin $readmemb("../data/file1.txt", rom1); $readmemb("../data/file2.txt", rom2); end It seems tha quartus doesn't allow me to initialize two ROMs in one verilog file. After I remove either one of the two $readmemb statement, quartus can synthesis successfully. I have also tried used two seperate initial blocks, each block contains one $readmemb. This doesn't solve the problem. I use the template provided by quartus to implement the two roms. Rom is inferred correctly. How do I solve this problem? I need to initialize multiple roms and rams in my project. Thank you!1 Reply
You will need to raise a myrequest ticket to see what the problem is.
