Quartus Prime Pro Crash (22.3)
I get a consistent crash during compile with Quartus Prime Pro 22.3. The trace is below:
Problem Details
Error:
Internal Error: Sub-system: CONSTRA, File: /quartus/db/constra/constra_s3_itf_impl.cpp, Line: 693
Attribute 'user.bb_f_ux_tx[0].bb.synth_lc_med_k_counter' value '32'd4_194_304' is invalid. Valid values are 0:4_194_303
Stack Trace:
Quartus 0x16a982: CONSTRA::VAR_SPACE_IMPL::set_var_value(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 0x4be (db_constra)
Quartus 0x47782e: TILEIP_WRITER::write_solver_var_space(CONSTRA::VAR_SPACE*, std::unordered_map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::hash<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::equal_to<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >*, TILEIP_TILE const*, TILEIP_RECONFIG_PROFILE*, TILEIP_STRING, TILEIP_F_TILE_PLACER const*, TILEIP_EM_TRANSLATOR*, bool, bool) + 0x188a (db_tileip)
Quartus 0x488ba4: TILEIP_WRITER::solve_tile(std::vector<std::pair<TILEIP_BUILDING_BLOCK_INSTANCE const*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<TILEIP_BUILDING_BLOCK_INSTANCE const*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >*, TILEIP_TILE*, TILEIP_RECONFIG_PROFILE*, TILEIP_STRING, TILEIP_F_TILE_PLACER const*, std::basic_string_view<char, std::char_traits<char> > const&, bool, bool, bool) + 0x5a8 (db_tileip)
Quartus 0x49195c: TILEIP_WRITER::run_placer(std::basic_string_view<char, std::char_traits<char> > const&, std::basic_string_view<char, std::char_traits<char> > const&, std::unordered_map<TILEIP_IP_INSTANCE const*, std::unordered_map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::vector<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, std::hash<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::equal_to<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::vector<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > > >, std::hash<TILEIP_IP_INSTANCE const*>, std::equal_to<TILEIP_IP_INSTANCE const*>, std::allocator<std::pair<TILEIP_IP_INSTANCE const* const, std::unordered_map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::vector<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, std::hash<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::equal_to<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::vector<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > > > > > >*, std::unordered_map<TILEIP_IP_INSTANCE const*, std::unordered_map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::vector<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, std::hash<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::equal_to<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::vector<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > > > > >, std::hash<TILEIP_IP_INSTANCE const*>, std::equal_to<TILEIP_IP_INSTANCE const*>, std::allocator<std::pair<TILEIP_IP_INSTANCE const* const, std::unordered_map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::vector<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, std::hash<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::equal_to<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, std::vector<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allo + 0xfa8 (db_tileip)
Quartus 0x4924b0: TILEIP_SOLVER_IF_IMPL::run_placer(std::vector<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::vector<TILEIP_SOLVER_IF::TILEIP_BB_PLACEMENT, std::allocator<TILEIP_SOLVER_IF::TILEIP_BB_PLACEMENT> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::vector<TILEIP_SOLVER_IF::TILEIP_BB_PLACEMENT, std::allocator<TILEIP_SOLVER_IF::TILEIP_BB_PLACEMENT> > > > >*, std::unordered_map<TILEIP_IP_INSTANCE const*, std::unordered_map<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::vector<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, std::hash<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::equal_to<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::pair<std::__cxx11::basic_string<cEnd-trace
Executable: qpro
Comment:
It crashed.
System Information
Platform: linux64
OS name: Red Hat
OS version: 8
Quartus Prime Information
Address bits: 64
Version: 22.3.0
Build: 104
Edition: Pro Edition
I believe it has to do with a new f-tile configuration that I am using - can you advise?
- RichardT_altera
For Internal Error related issue, we able to advise if only there is similar case in our database or found in KDB Intel.
As it turns out, there is no similar internal error happened before in other customers.
With that, we will need your design .qar file to duplicate the error as without the error duplication from our side, it would be hard to find a workaround/solution.
Richard Tan
- RichardT_altera
Could you help to share the design .qar file? Please do understand that without it, there is not much that I can help you.
Richard Tan
- RichardT_altera
Thank you.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
