ELIT1
2 years agoQuartus Prime Pro 24.1 RAM Inference problems
When trying to infer Block-RAM from the attached System Verilog code the following problems occurred: 1 - when used 'rd_outcken' input (RDOUTCKEN_USED = "YES") - out registers not packed to memory ...
ELIT1
2 years agoHi.
Altera memory blocks have 4 clock enable inputs:
clocken0, clocken1, clocken2, clocken3
and 6 parameters:
clock_enable_input_a, clock_enable_output_a,
clock_enable_input_b, clock_enable_output_b,
clock_enable_core_a, clock_enable_core_b.
By setting these parameters: "BYPASS" / "NORMAL" / “ALTERNATE” / “USE_INPUT_CLKEN” -
determines the connection and use of clock enable inputs.
Please see the attached file created by Quartus Prime Pro 24.1 IP PARAMETERS EDITOR.
I want to have a synthesizable RTL equivalent.
ELIT1
