Quartus Prime Pro 19.2 quits unexpected with following error report. Does anybody know, what's the problem in this case?
Problem Details
Error:
Internal Error: Sub-system: CDB_SGATE, File: /quartus/db/cdb_sgate/cdb_sgate_component.cpp, Line: 926
Port direction does not agree.
Stack Trace:
0x5f4ac: CDB_SGATE_COMPONENT::retrieve_known_port + 0x3ba6c (db_cdb_sgate)
0x4b568: qis_get_component_ports + 0x118 (synth_qis)
0x4874a: QIS_RTL_STAGE::IMPL::merge_nodes + 0x64a (synth_qis)
0x49219: QIS_RTL_STAGE::IMPL::merge_sgate_models + 0x339 (synth_qis)
0x43a02: QIS_RTL_STAGE::IMPL::dissolve_partition + 0x412 (synth_qis)
0x53641: QIS_RTL_STAGE::IMPL::uniquify + 0x9b1 (synth_qis)
0x54778: QIS_RTL_STAGE::IMPL::uniquify + 0xc08 (synth_qis)
0x1bb98: qis_uniquify + 0x1f8 (synth_qis)
0x16442: TclNRRunCallbacks + 0x62 (tcl86)
0x17c4d: TclEvalEx + 0x9ed (tcl86)
0xa6a8b: Tcl_FSEvalFileEx + 0x22b (tcl86)
0xa5136: Tcl_EvalFile + 0x36 (tcl86)
0x14ebc: qexe_evaluate_tcl_script + 0x3fc (comp_qexe)
0x13f72: qexe_do_tcl + 0x4b2 (comp_qexe)
0x1a34e: qexe_run_tcl_option + 0x5ee (comp_qexe)
0x18195: QCU::DETAIL::intialise_qhd_and_run_qexe + 0x95 (comp_qcu)
0x290bc: qcu_run_tcl_option + 0x2ec (comp_qcu)
0x19c58: qexe_run + 0x438 (comp_qexe)
0x1ad8a: qexe_standard_main + 0x26a (comp_qexe)
0x34d9: qsyn2_main + 0x129 (quartus_syn)
0x14a08: msg_main_thread + 0x18 (CCL_MSG)
0x160ae: msg_thread_wrapper + 0x6e (CCL_MSG)
0x20fb0: mem_thread_wrapper + 0x70 (ccl_mem)
0x13f8d: msg_exe_main + 0x20d (CCL_MSG)
0x4dd4: __scrt_common_main_seh + 0x11c (quartus_syn)
0x17bd3: BaseThreadInitThunk + 0x13 (KERNEL32)
0x6cee0: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus_syn
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 19.2.0
Build: 57
Edition: Pro Edition
- KhaiChein_Y_Intel
Can you clean the project, Project > Clean Project > Ok and recompile?
If the problem persists, kindly provide a test case to reproduce the error.
- Elegan
Cleaning the project didn't help.
As I want to evaluate the update from Cyclone V to Cyclone 10 GX it is a project generated with Quartus Prime 18.0, which I tried to migrate to Quartus Prime Pro 19.2.
IP Generation -> O.K.
Analysis & Synthesis runs fine until "Creating instance-specific data models and dissolving soft partitions" where it crashes.
It must be design-related because trying to compile a Cyclone 10GX example design worked without any problem.
I can provide you with the archived project, but not in the community.
- KhaiChein_Y_Intel
I have sent an email to you. Please let me know if you did not receive.
- Elegan
yes, I received the email.
The problem is, that at the moment I do not have the simple test case, as the problem only occurs at one specific project.
I tried to build a simple project in Quartus Prime 18.0 and then do the migration to Quartus Prime 19.2. But no problem in this case.
Another problem is, that I could not archive the whole project, because it needs Analysis & Elaboration to know which files need to be archived and this is the point, where it fails.
Next step, I will try to find out, which specific part of the project causes Quartus to crash.
Maybe the cause is an IP, or something like that.
Can you tell me what is meant by "Port direction does not agree." in the reprt file?
Maybe this help to point me to the right direction.
Christian
- KhaiChein_Y_Intel
It is difficult to find the root cause without the test case due to limited information in the error message.
It has something to do with a connection of a module where the port direction does not match the expected one. This is often related to connecting bidir (e.g. bidir to input or vice versa). Or possibly the size of the port doesn't match, or it is connecting a bus to a scalar. Or it could be that the component does not match the entity.
- Elegan
O.K. the problem was an old custom generated tristate component. It is part of a component which was generated long time ago in block editor, but as it is still working, it is still in use.
By the way I found out that in Quartus Prime Pro 19.2 it is no more possible to create a symbol out of an HDL-File, correct?
I know, that support of block and symbol-editor is getting lower and lower, but although I write the specific components in VHDL, I liked it to keep the top-level-design in blocks as in my opinion it is more clear.
- KhaiChein_Y_Intel
Yes. It is no longer supported. You may open the RTL Viewer by clicking on Tools > Netlist Viewers > RTL Viewer. It seems like you found a root cause of this error. Could you provide a simple test case for error replication?
- Elegan
- KhaiChein_Y_Intel
Thanks for the attachment. I have file a case to report this error.
- KhaiChein_Y_Intel
I received the feedback from the team today. Please see the feedback below.
The issue is that Tri8.bsf shows that tridata is of type bidir, but in Tri8.vhd, tridata is an output. You need to fix the design so that the Tri8 symbol used in TriTest.bdf matches the implementation of Tri8 in Tri8.vhd. Right now the Tri8 symbol says that tridata is a bidir but in Tri8.vhd tridata is an output. If you make the two match the design goes through.
You are encourage to move away from using bdf. It is much better to a modern language that is also used by other tools, i.e. Verilog, systemverilog or vhdl.
