Quartus Prime Pro 19.2 Linux missing devices converting programming files, crashing
- 7 years ago
When you convert the sof file, you should select "10AX115S2" as this is the production device which is on your board.
For the programming issue, may I know if you are using AS (Active Serial) configuration mode? Could you check your board MSEL to see if it is selecting AS mode? If no, please change the MSEL to AS before powering up the board.
- RBish37 years ago
Ahhh, excellent, that's sorted the problem out John. For whatever reason, the newer tutorials don't specify that you have to set the MSEL jumpers into the Active Serial mode - hadn't made the link that the files generated earlier were configured as such. The periphery image is programmed using JTAG so its relevance wasn't particularly obvious.
Thanks very much!
