8 years agoQuartus Prime (Lite Edition): timing violation signals on Netlist
How can I look signals out that cause timing violations (setup/hold) on Netlist. If there are some timing violations on some signals, I can put FFs between those signals to prevent setup/hold timi...
8 years agoUse the Timing Analyzer (aka TimeQuest). From the Quartus Compilation report in the Timing Analyzer folder, right-click the clock domain(s) in the summary reports that are failing timing and select Report Timing. This will create a detailed timing report in the timing analyzer. You can then right-click a failing timing path and cross-probe to the Chip Planner or the Technology Map Viewer to get more detail about the failing path(s).
