KDK-2023's avatar
KDK-2023
3 years ago
Quartus Prime Lite edition 22.1.1(Latest)\ModelSim availability
Hi there,
As per the Release Notes for the above referred release it looks like ModelSim is no longer available but the Questa. Can someone confirm that for me please?
Many thanks!
  • With Quartus 21.1, Simulator switched to Questa. You can still simulate most designs with older ModelSim versions.
  • FvM's avatar
    FvM
    • KDK-2023's avatar
      KDK-2023
      Hi FvM,
      Thanks for jumping in here.
      I see, then I guess I should downgrade my suite to say, @ least 20.1 in order to be able to get ModelSim in. Unless the latest suite version would allow me to incorporate ModelSim from 20.1 in.
      Kind regards,
  • SyafieqS's avatar
    SyafieqS
    Quartus version Lite/STD of 20.1 is the last to support modelsim.
    Onward is Questasim, thus I guess it is correct.
    You may check it manually in download page
  • sstrell's avatar
    sstrell
    ModelSim and QuestaSim basically work the same. Very little reason to not use QuestaSim. I believe it runs faster and supports larger designs.
  • SyafieqS's avatar
    SyafieqS
    Let me know if there is any update at your end
  • SyafieqS's avatar
    SyafieqS
    p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
