Quartus Prime Lite 17.0 cannot use the device
Hi Mingliang,
This error could happen if you didn't install the installer package for Quartus Prime Lite.
Kindly go to windows start menu and find the program called 'Device Installer (Quartus Prime Lite 17.0) and try to install the .qdz file.
These .qdz file is merely the installer package and without installing it the file does nothing.
Thank you.
Hi Calvin,
Thanks for the reply.
Please find the picture below (from Device Installer). From this picture, the two devices (Cyclone IV and V) are already installed.
I even tried to uninstall everything. Then reinstall the Quartus Prime Lite only and install the device using device installer later. It still doesn't work. I repeat this procedure for version 16.1, 17.0 and 18.1.
Mingliang
