Quartus Prime 20.1 LITE Nios Eclipse Not Opening
Hi all, I installed Quartus Prime 20.1 LITE on Windows latest build, BUILD 18363.1256
But Nios2 Eclipse will not start, no GUI
I have tried instructions from these posts,
https://community.intel.com/t5/Programmable-Devices/Why-Nios-II-cant-open/m-p/1235611#M78141
But, none of them worked. Please help. I can down grade to 18.1, but this is my last option
Thank you all,
- EricMunYew_C_Intel
Can you follow below to install again:
1. install WSL for windows
i. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/nios2/n2sw_nii5v2gen2.pdf (chapter 2.1)
Note: Windows 10 build version 16215.0 or higher is the recommended operating system version.
ii. After installation has successfully completed, launch Ubuntu 18.04.
iii. Install additional distro packages required for Nios II EDS using the following commands:
a. sudo apt-get update
b. sudo apt install wsl
c. sudo apt install dos2unix
d. sudo apt install make
2. install nios2 eclipse folder
3. After re-installation, can you download the patch from below KDB:
- WUnkn
Thank u. May I ask if future Quartus Prime release will NOT include Nios2 Eclipse stuff such that user needs to install Eclipse components manually
- vishnu062
Hope your problem has resolved if not
Follow this link
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/nios2/n2sw_nii5v2.pdf
To page number 20
follow the instructions given in "Installing Eclipse IDE into EDS"
I too faced the same issue. I followed the above procedure given in pdf and it got resolved
