8 years agoQuartus Prime 17.1 with Intel HLS Compiler issues
Hi, I have installed MS Visual Studio 2010 and Quartus Prime 17.1 with Modelsim Intel FPGA Starter Edition 10.5b to my Windows 10 computer. I am trying to run counter example in hls. Here, the output...
8 years agoHi,
Counter.cpp have only two printf statement for the pass and fail condition, count values are not displayed. To see the count values introduce printf statement for seeing the count values at console. Example: for(unsigned int i=0; i < SIZE; ++i) {
if (result != i) {
printf("ERROR: Expected %u, found %u\n", i, result);
pass = false;}
else{
printf("Expected %u, found %u\n", i, result);
} You can also run test-x86-64.exe to see the result after compilation using command build.bat test-x86-64 https://alteraforum.com/forum/showthread.php?t=57668 Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
