9 years agoQuartus Prime 16.1 crashes at very start of Assembler phase with NO ERROR MESSAGE
My project (GHRD derivative with custom IP and EMIF blocks) gets through the first phases of compilation fine, but about 10 seconds into the Assembler phase (just enough time to output the first 3 li...
9 years agoHi VJR
1/ "However, those settings were still getting applied to my project" => make sure to check clear output directories checkbox in order to regenerate you IP files with the new options. 2/ I've tried to reproduce your issue. So I've generated an example design of Arria10 EMIF using quartus 16 pro and an I've added two additional clocks. The run was successful till assembling phase (which in contradiction with what you said). could you give more details about your issue and the error returned by the assembler. thanks kais
