15 years agoI think what works best is quite dependent on your design.
Personally, I have never seen the multi processor option in Quartus help. However, some of the results posted in this thread indicate it can be a big help. Has anyone here ever done testing with 32 bit vs 64 bit? I also tested this with the same design I mentioned earlier. I found that using 64 bit took slightly longer to compile. In this case, I would guess if your design can compile with less than about 2 gigs of RAM usage, 32 bit is probably a little faster. For larger designs, 64 bit may be a big advantage. One thing I have not tried is compiling under Windows vs Linux. Does anyone have any experience with this?
