jmcguire3
3 years agoQuartus P-Tile PCIe IP config crashes
Trying to configure a basic PCIe interface on the Agilex F014 EVM, and the P-Tile IP configuration crashes if I disable either the read-data-mover or write-data-mover functions under the Avalon-MM Se...
Wincent_Altera
3 years agoHi,
Please apologies for the inconvenience cause to you due to the features missmatch.
Is there anything you think I can help you on that ?
Wincent_intel
- jmcguire33 years ago
Well, I thought I would try to work within the system rather than fight it. Opened a new, clean design and instantiated the PCIe Avalon-MM IP core. My thought process - leave the existing DMA / memory-mover construct in place, and just spackle-on an I/O port construct.
Found that making any change to a parameter crashes the elaborator script. The attached screen grab shows the result of changing only the Revision ID field ... you know, something that you would want to update when you change the contents of the design. Tested this in both 22.3 and 22.4 versions of Quartus Pro.
