18 years agoJust a short follow up. Apparently, the template in Quartus II 7.2 is wrong. The one below works as expected. Now my next question is how to infer dual port memory without bypass. I suspect you can't (without messing with synthesizer settings which is not a portable solution).
Thanks Tommy module single_port_ram ( input [(DATA_WIDTH-1):0] data, input [(ADDR_WIDTH-1):0] addr, input we, clk, output [(DATA_WIDTH-1):0] q ); parameter DATA_WIDTH = 8; parameter ADDR_WIDTH = 6; // Declare the RAM variable reg [DATA_WIDTH-1:0] ram[2**ADDR_WIDTH-1:0]; reg [ADDR_WIDTH-1:0] addr_reg; always @ (posedge clk) begin // Write if (we) ram[addr] <= data; addr_reg <= addr; end // Read returns NEW data at addr if we == 1'b1. This is the // natural behavior of TriMatrix memory blocks in Single Port // mode assign q = ram[addr_reg]; endmodule
