--- Quote Start ---
I am wondering what the best way is to organise a design using quartus. Quartus output file together with design files. How can I make quartus to organise the ouput files by folders (e.g. jic, sof, map .. and so on)?
--- Quote End ---
Use Tcl scripts to drive the process.
I use Tcl to generate Modelsim and Quartus files in tool-specific build directories. This allows my source and scripts to be located in their own unique area (which is checked into a code versioning system) and it allows me to build with different tool versions installed onto the same machine.
Look at the source with these tutorials/documents:
http://www.ovro.caltech.edu/~dwh/correlator/cobra_docs.html http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial Cheers,
Dave
