10 years ago
Quartus not recognizing VHDL functions in 2008 version of ieee.numeric_std
I have a bunch of VHDL code that works in SynplifyPro, but I'm having trouble getting it working in Quartus. It appears that Quartus is using an outdated version of ieee.numeric_std, but I have no idea how or where that is specified. I am using a tcl-based compile flow, which includes the following command:
set_global_assignment -name VHDL_INPUT_VERSION VHDL_2008
But when I run synthesis, I get error such as:
Error (10327): VHDL error at <file>.vhd(<line>): can't determine definition of operator ""sra"" -- found 0 possible definitions
Error (10476): VHDL error at <file>.vhd(<line>): type of identifier "<signal>" does not agree with its usage as "std_logic_vector" type
These functions are clearly defined in:
$QUARTUS_INSTALL_DIR/libraries/vhdl/ieee/2008/std_1164_vhdl2008.vhd
$QUARTUS_INSTALL_DIR/libraries/vhdl/ieee/2008/numeric_std_vhdl2008.vhd
and not defined in:
$QUARTUS_INSTALL_DIR/libraries/vhdl/ieee/1993/std_1164_vhdl1993.vhd
$QUARTUS_INSTALL_DIR/libraries/vhdl/ieee/1993/numeric_std_vhdl1993.vhd
Does anyone know of way to confirm that Quartus is using the outdated packages, and how to specify using the 2008 packages?
I am using Quartus II Version 15.0.0
