9 years agoQuartus message re output drivers
Quartus gives me a message about no output drivers on pins. I have tried putting the .alt driver on the pins, no difference. So what drivers am I supposed to put on the pins?? The quantity of usel...
9 years ago --- Quote Start --- The 7400 comes from a Quartus library, and is put into the .BDF file. Why would Quartus supply a library file that would not work in their program? That makes no sense. I have since spent more time, and recompiled the program, and the messages go away. I deleted the .V file and forced the program to use the .BDF file. It appears that when both files are present, Quartus will corrupt the .V file. --- Quote End --- It works perfectly fine - it just will not convert to legal Verilog (because it is a very old library, back from when HDL was used far less used.) The problem you had was that the .v file with illegal syntax took preference over the .bdf file
