9 years agoQuartus message re output drivers
Quartus gives me a message about no output drivers on pins. I have tried putting the .alt driver on the pins, no difference. So what drivers am I supposed to put on the pins?? The quantity of usel...
9 years agoThen I get this warning:
Warning (169064): Following 32 pins have no output enable or a GND or VCC output enable - later changes to this connectivity may change fitting results These pins are a memory bus, and although you can draw a bidirectional pin on the .BDF drawing, it comes with no output enable. How are you supposed to do that?
