9 years agoQuartus message re output drivers
Quartus gives me a message about no output drivers on pins. I have tried putting the .alt driver on the pins, no difference. So what drivers am I supposed to put on the pins?? The quantity of usel...
9 years agoCan you post an example of one such message - including whether it's a 'warning', 'error' or 'info' message?
The vast quantity of 'useless messages' are there to help you determine whether Quartus has interpreted your design correctly. If Quartus is stating there is not driver on an output signal, when you think there should be (for instance), then the messages allow you to pick up on that. Cheers, Alex
