9 years agoquartus_map fails with "17942 No Open project exsists" after adding probes
I have a design with a couple of hundred probes. At some point I make a change to the signal tap signal list. After that change I get the following error message : Error (17942): No open proj...
9 years agoI saw something where someone got the same messages.
1) They were able to get around it by turning off Parallel Synthesis. 2) It supposedly was fixed in Q16.1 So those are two things to try.
