Richo25
3 years agoquartus libprotobuf.so.14 requirement
Hi quartus in 22.1std requires libprotobuf.so.14 to run.
This is a 5yr old version of the library and is not installed on later dev environments.
libprotobuf is up to version 25
I see there wa...
Richo25
3 years agoHi Richard
I installed it on RHEL 9.
The problem came down to the quartus installer not setting permissions correctly.
All the libraries were there (in quartus flatpak library folders).
It seems to set a lot of the permissions for libraries etc to user only, in this case the owner was root as they performed the installation.
However all things things that need to be executed including libraries should be set with 555 permissions so other users can read and execute them.
Config/data files etc files should be set with 644 permissions.
