Richo25
3 years agoquartus libprotobuf.so.14 requirement
Hi quartus in 22.1std requires libprotobuf.so.14 to run.
This is a 5yr old version of the library and is not installed on later dev environments.
libprotobuf is up to version 25
I see there wa...
Richo25
3 years agoAnd 10 minutes later I found the problem with this one.
Half the libraries are not set with other rx permission in the quartus/ linux64 folder..
Fixed with sudo chmod o+rx *so* on that folder.
Now I'm just getting a core dump after resolving all libs ... yay not...
