Quartus jtagd fails and unable to program MAX10 under Linux (18.1.0.625)
Yes, i have tried unplugging/plugging the USB Blater cable, putting it into different USB ports, different cables, different USB Blasters, different MAX10 boards, tried it from different user accounts (including root), on 4 different Linux systems (3 running Fedora27 and 1 running Redhat7), and tried running jtagd as root. This all fails apart from on one Lenovo thinkpad Laptop (running exactly the same Fedora27 and Quartus installation as far as I can tell) which works fine. The CPU types and speeds are different between these systems, the only thing I can think of which is different.
Note we were able to program fine until about November/December 2018 when it stopped working. As stated we can program fine with openocd (using the same USB Blaster) on all of the systems, but it is slow.
JohnT the "real" driver must be the standard Linux generic USB driver, jtagd will "probably" use a user level API layer like libusb to communicate with the Linux driver. There is no driver for Linux in the Quartuis distribution as far as i am aware, or is there one we can use ?
I have had some progress, but still don't know what is happening. On the laptop running Fedora27 where programing works I have three users setup: root ,terry, test. The programming only works for the user "terry". Now it gets really strange.
If I manually start the jtagd program as the user root with the command: "jtagd --user-start --config /homel/terry/.jtagd.conf" programming works.
If I manually start the jtagd program as the user root with the command: "jtagd --user-start --config /root/.jtagd.conf" programming fails. The ".jtagd.conf" file does not exists in all cases.
If I manually start the jtagd program as the user terry with the command: "jtagd --user-start --config /homel/terry/tmp/.jtagd.conf" programming works (the directory /homel/terry/tmp exists).
If I manually start the jtagd program as the user terry with the command: "jtagd --user-start --config /tmp/.jtagd.conf" programming fails.
Now even stranger as the test user with a home directory of /homel/test "jtagd --user-start --config /homel/test/.jtagd.conf" programming fails.
Using "jtagd --user-start --config /homel/test-55/.jtagd" (/homel/test-55 does not exists) programming is fine.
Using "jtagd --user-start --config /tmp/.jtagd.conf" programming fails.
If I create an empty .jtagd.conf file it does not affect things.
Something really strange is going on here with jtagd ... Any ideas ?
