TBarn2
7 years agoQuartus jtagd fails and unable to program MAX10 under Linux (18.1.0.625)
I am having a problem programing MAX10 devices under Linux. It used to work fine but I think some software updates have changed things (kernels?). I am running Fedora29 (although I have the same issu...
JohnT_Altera
7 years agoFrom the information provided, it working with the blaster. I am not sure what is causing the issue with using generic USB driver. I would recommend you to use USB-Blaster driver
